[GRASS-user] Re: Grid Mismatch while importing with 6.4.1 and
6.4.2
antonio.rocha at deimos.com.pt
Wed Mar 28 08:52:36 EDT 2012
A few minutes after your message, Markus Mets sent another message in
disagreement with this.
Any other inputs?
On Wed, 28 Mar 2012
14:49:10 +0200, Micha Silver wrote: On 03/28/2012 02:06 PM,
antonio.rocha at deimos.com.pt [1] wrote:
Greetings
Daniel lee
suggested me that the problem might be the defined region. But, as far
as I know, Defined region has no impact over importing data. This is
true right?
AFAIK, not quite true. Vector data are imported "whole"
with no regard to the region. But raster imports honour the current
region. So only that part of the imported raster covered by the current
region is imported.
Furthermore the module r.in.gdal has a flag '-e'
to reset the current region to the extents of the imported data, and
thus importing the whole dataset.
Thanks
Antonio
Am 27. März 2012
11:52 schrieb António Rocha : Greetings
I have imported a Raster image
in GRASS 6.4.1 with r.in.gdal and now, when I import the same raster
(with 6.4.2) there is a grid mistmatch (more or less a quarter pixel)
from previous import to the current import. The image is the same, the
Location/Mapset also the only difference is the update of GRASS. Is this
expected?
Thanks
Antonio
This mail was received via Mail-SeCure
System.
grass-user
grass-user at lists.osgeo.org
[3]
http://lists.osgeo.org/mailman/listinfo/grass-user [4]
This mail
was received via Mail-SeCure System.
Links:
[1]
mailto:antonio.rocha at deimos.com.pt
[2]
[3]
mailto:grass-user at lists.osgeo.org
[4]
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120328/721fef08/attachment.html
