[GRASS-user] Lidar points height from ground
Daniel Victoria
daniel.victoria at gmail.com
Fri Mar 30 07:00:07 EDT 2012
I need to calculate the number of points at different height levels. That
is, how many points are from 0 to 5 meters? And from 5 to 10? And so on. So
I believe I need to work with vector points and a database. Or is there
another way?
Thanks
Daniel
On Mar 30, 2012 6:47 AM, "Daniel Lee" <lee at isi-solutions.org> wrote:
> Hi there,
> I don't work too much with vectors, but my personal experience with them
> has been fairly slow, perhaps due to the topology. If you have access to
> the raw point cloud, you could try importing the ground and surface points
> as separate rasters using r.in.xyz and then use r.mapcalc to get the height
> by subtracting the ground from the surface raster. Or do you definitely
> need vector points as an output?
> Best,
> Daniel
> B.Sc. Daniel Lee
> Geschäftsführung für Forschung und Entwicklung
> ISIS - International Solar Information Solutions GbR
> Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
> Deutschhausstr. 10
> 35037 Marburg
> Festnetz: +49 6421 379 6256
> Mobil: +49 176 6127 7269
> E-Mail: Lee at isi-solutions.org
> Web: http://www.isi-solutions.org
> ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber:
> Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses
> des Deutschen Bundestages, sowie durch die Europäische Union,
> Zuwendungsgeber: Europäischer Sozialfonds.
> Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster
> Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and
> Remote Sensing und dem GIS-Lab Marburg.
> Am 29. März 2012 22:59 schrieb Daniel Victoria <daniel.victoria at gmail.com>
>> Hi all,
>> I'm trying to calculate the height from the ground of several lidar
>> points (15million) in order to get the number of points that occur at
>> different height levels. I read some older posts about using r.in.xyz
>> (or r.in.lidar in grass 7) but I could not understand how to count the
>> number or points that have height from 0 to 5 m above the ground, for
>> instance. So, I'm trying to do the following.
>> 1) import points using v.in.lidar (Grass 7 ubuntu linux)
>> 2) create a column in the database for the ground height and one for
>> elevation
>> 3) populate height column from ground raster (generate in another
>> process) using v.what.rast
>> 4) calculate elevation as zcoord - ground for each point (v.db.update)
>> As you might imagine, this takes a long time. Just to import a 400Mb
>> lidar file takes around 50min.
>> Is there any easier way that I'm not envisioning?
>> I'm running Grass 7 with liblas on a Ubuntu Virtual Machine and sqlite
>> backend.
>> Thanks
>> Daniel
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120330/d6e2b4e6/attachment.html
