[GRASS-user] extract single watershed from r.stream.order-result
Johannes Radinger
JRadinger at gmx.at
Wed May 2 08:36:23 EDT 2012
I followed the GRASS GIS commands J. Jasiewicz used
in his r.fuzzy paper to extract the streams as rasters
from the spearfish dataset.
What I did so far:
r.watershed -f --overwrite elevation=elevation.10m at PERMANENT accumulation=accum
r.mapcalc accum_abs=abs(accum)
r.stream.extract --overwrite elevation=elevation.10m at PERMANENT threshold=200 stream_rast=stream
Now I'd like to select only one of all drainage networks (watershed). I am interested in the right network of the two main river networks in spearfish
Is there an easy way to get only that main watershed into a new map? I thought about identifying it via the main outflow pourpoint at 602140|4927950...
Any suggestions?
Best regards,
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
