[GRASS-user] v.buffer database error
Markus Neteler neteler at osgeo.org
Thu May 10 04:12:39 EDT 2012
On Thu, May 10, 2012 at 9:56 AM, Falko Engel <falko.engel at web.de> wrote:
> Am 09.05.2012 23:32, schrieb Markus Neteler:
> thanks for that hint! It helped finding the error.
Excellent!
> So far the problem is clear. v.buffer seems connect to the old DB on
> localhost.
With v.db.connect you can connect the map to the correct attribute
table.
> But there is another aspect:
> When I create a new dataset (using g.copy) with an a attribute table in the
> (correct) DB on the network drive v.buffer recognizes it! This new table
> doesn't exists on localhost.
> Is there a way to pipe the debugging info to a file?
Yes, for example:
yourcommand > yourcommand_stdout.txt 2> yourcommand_stderr.txt
or
yourcommand 2>&1 > yourcommand.txt
So the output is redirected ">" into files.
Markus
