[GRASS-user] High-resolution agricultural land cover from
satellite imagery
山田 康晴
yamaday at affrc.go.jp
Mon May 14 21:18:52 EDT 2012
I wonder why you want to use the Landsat TM data for the analysis of
the high resolusion agricultural land cover.
The Landsat TM, not ETM, has very long histry and is not the High-resolution
data as for both spatial and frequential points of view.
There are so many research papers for the analysis on agricultural
land cover.
The "esa" or Italy scientists must have much information for your interest.
Are you a scientist in Italy?
> We are targeting an agricultural area in southern Italy (several
> thousands hectares) for which we have full orthophoto coverage (0.5
> meters resolution), and Landsat TM data can apparently be downloaded
> freely from <http://glcf.umd.edu/data/landsat/>. High-resolution
> agricultural land cover might seem overkill, but the area is highly
> fragmented and hence standard CORINE land cover data tend to classify
> most of the land as mixed types (not very helpful).
> I would like to ask a general recommendation on the best way to approach
> an agricultural land cover task such as the one outlined above, together
> with possible info on previous implementation of increasing spatial
> resolution of agricultural land cover maps in GRASS via neural networks
> or other approaches.
> Kind regards, thanks in advance and apologies for a long post,
> Luigi
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
