[GRASS-user] XY trace plots
Daniel Victoria daniel.victoria at gmail.com
Sat May 19 09:12:36 EDT 2012
Not sure it will work but maybe you will need to use some 3d view (nviz)?
Cheers
Daniel
On May 19, 2012 8:33 AM, "John Nicholls" <johnnicholls at fastmail.fm> wrote:
> Hello
> I have an ascii file in .csv format containing x/y coordinates and z
> values. Z column data represents geophysical data collected along
> parallel lines (X and Y coordinates). I wish to display this data in a
> format similar to an XY trace plot (see image example), where z data
> recorded along individual traverses in the field can be displayed as a
> raster image of parallel lines showing both negative and positive
> responses along each line. So far I have imported small data sets using
> both v.in.ascii  and v.in.lines with also use of v.build.polylines but
> the results only produce a single flat line. It is most likely I am not
> going the right way about this, hence my query. I have searched the mail
> archive in advance of this mail and found no relevant reference. Is it
> possible to produce such a display with GRASS?
> Thank you in advance,
> John Nicholls.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120519/3d9eb3f9/attachment.html
