[GRASS-user] installing Grass 7 on ubuntu 11.04
    Sören Gebbert
    soerengebbert at googlemail.com
    Thu Nov  1 10:55:06 PDT 2012
Hi Manish,
please make sure that all requirements for GRASS are fulfilled. Using
./configure --help will show you all switches that can be set. In your
particular case is the libtiff-dev package from Ubuntu missing. Use this
command:
apt-get install libtiff-dev
to install the development files (header) for libtiff. This will solve the
tiff error.
Please have a look at [1] and install all missing dependencies using
apt-get or aptitude.
Best regards
Soeren
[1] http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies
2012/11/1 Manish Gautam <manish.gautam29 at gmail.com>
> Hi,
> Thanks for your responses.
> I followed till this step
> http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
> (about the ./configure command not working earlier, this time it
> worked as I didn't use the ubuntu repository to install rest of the
> prerequisites, but downloaded manually and moved to the source code
> directory and then configured it accordingly).
> In the step of Grass_GIS, ./configure worked (but it says error:
> unabale to locate TIFF includes, rest worked).
> the  step -
> compile & install
> make -j2 && sudo make install && sudo ldconfig
> says "include/Make/Vars.make:1: include/Make/Platform.make: No such
> file or directory
> make: *** No rule to make target `include/Make/Platform.make'.  Stop."
> and here I am stuck.
> Manish
> On 31 October 2012 22:44, Nikos Alexandris <nik at nikosalexandris.net>
> wrote:
> > [forgot to cc to the list]
> > Manish Gautam:
> > > I am finding it difficult to install Grass 7 on my pc. I use Ubuntu
> 11.04.
> > > I have tried to install it using the instructions given in the link
> > > http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu. However, I am
> able
> > > to download and install the dependencies.
> > Could you please post the exact command you instructed?  And, any
> positive or
> > negative output?
> > > Another thing is how the command ./configure is to be used on Ubuntu
> 11.04.
> > > the terminal says the ./configure command not found though the
> necessary
> > > compiler is already been installed on the machine.
> > Actually, the "configure" executable file/program is to be ran from
> within the
> > directory in which it is located, i.e.  the grass source code root
> directory.
> > From within which directory do you try to execute ./configure?  And
> along with
> > which parameters?
> > > (Can I download the binary file from here
> > > http://grass.fbk.eu/grass70/binary/linux/snapshot/ and install from
> here ?
> > I haven't tried that yet. Maybe someone else can help with this.
> > > Though again I am unable to run the installation script given there or
> > > extracting the tar file)
> > Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- n�chster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121101/09a54686/attachment.html>
