[GRASS-user] installing Grass 7 on ubuntu 11.04
    Vaclav Petras
    wenzeslaus at gmail.com
    Fri Nov  2 00:41:36 PDT 2012
On 1 November 2012 13:32, Manish Gautam <manish.gautam29 at gmail.com> wrote:
> worked as I didn't use the ubuntu repository to install rest of the
> prerequisites, but downloaded manually and moved to the source code
> directory and then configured it accordingly
Note that manual downloading and compiling of source codes is usually
not necessary. Using packages from Ubuntu repository should be
sufficient.
If not you can use ubuntu-gis ppa repository. This is how you add it
to your system:
apt-get -y install python-software-properties
add-apt-repository ppa:ubuntugis/ppa
apt-get -y update
But to be honest, now I'm not sure if this ppa repository, is really necessary.
By the way, you may be interested also in this thread:
http://osgeo-org.1560.n6.nabble.com/Please-update-quot-Compile-on-Ubuntu-quot-page-in-Wiki-td4999519.html
Vaclav
