[GRASS-user] r.drain : error message
    laurent celati
    lcelati at latitude-geosystems.com
    Fri Nov  2 03:13:04 PDT 2012
Hello,
I have an error message when i run "rdrain". For information i use Grass
tools via qgis. I imported a DEM file (32 bit reel/ PCIDSK format .pix
/Pixel size x & y : 15m) in my Grassdata set. The projection of the DEM file
and of the Grass project(location) is UTM 32N Wgs84.
When i run r.drain. i have an error message saying : the module has been
killed.
The problem seems come from corrdinates ("Map coordinates of starting
points). But I have entered UTM coordinates in input.
Could you throw light for me please?
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-drain-error-message-tp5013499.html
Sent from the Grass - Users mailing list archive at Nabble.com.
