[GRASS-user] r.drain : error message
    Markus Neteler
    neteler at osgeo.org
    Sun Nov  4 05:40:13 PST 2012
On Fri, Nov 2, 2012 at 11:13 AM, laurent celati
<lcelati at latitude-geosystems.com> wrote:
> Hello,
> I have an error message when i run "rdrain". For information i use Grass
> tools via qgis. I imported a DEM file (32 bit reel/ PCIDSK format .pix
> /Pixel size x & y : 15m) in my Grassdata set. The projection of the DEM file
> and of the Grass project(location) is UTM 32N Wgs84.
> When i run r.drain. i have an error message saying : the module has been
> killed.
Which operating system do you use? and which GRASS version?
> The problem seems come from corrdinates ("Map coordinates of starting
> points). But I have entered UTM coordinates in input.
We need to know a bit more about the command you issues.
Markus
