[GRASS-user] installing Grass 7 on ubuntu 11.04
    Manish Gautam
    manish.gautam29 at gmail.com
    Sat Nov  3 22:56:17 PDT 2012
thank you all for your suggestion. finally it is installed and working fine.
Regards,
Manish
On 4 November 2012 03:25, Nikos Alexandris <nik at nikosalexandris.net> wrote:
> Manish Gautam:
>>This time I am getting the following problems :
>> 1. So, when I run ./configure after installing Proj 4, GEOS and GDAL,
>> this error comes
>> checking for tcl.h... no
>> configure: error: *** Unable to locate Tcl includes.
> Are they installed?
>> 2.and using this
>> --with-tcltk-includes="/usr/include/tcl8.5/"
>> It shows the following message:
>> "checking for location of Tcl/Tk includes... /usr/include/tcl8.5/
>> configure: error: *** Tcl/Tk includes directory /usr/include/tcl8.5/
>> does not exist. "
> # What do you get by instructing
> sudo dpkg -l | grep tcl
>> 3. do I need to run this "svn checkout
>> https://svn.osgeo.org/grass/grass/trunk" ?
> Only if you want to download GRASS 7 (=development version, aka grass_trunk)
> via SVN.
>> it gives this message : " svn: OPTIONS of
>> 'https://svn.osgeo.org/grass/grass/trunk': could not connect to server
>> (https://svn.osgeo.org) "
>> [is it because of the proxy in the internet connection I am using ? I
>> tired it several times but it never got connected.]
>> 4. so I skipped the above step and instead downloaded the grass 7
>> source files and extracted it in the source directory. then i ran
>> ./configure \ and got the following error
>> " checking whether to use FFMPEG... yes
>> checking for location of FFMPEG includes... /usr/include/libavcodec
>> /usr/include/libavformat /usr/include/libswscale
>> configure: error: *** FFMPEG includes directory
>> /usr/include/libavcodec does not exist. "
> You probably have to install these also!  Please check the
> <http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu#Dependencies> and try
> to install all of them.  Or try directly (you can also remove the "\" and put
> all in one line):
> sudo apt-get install \
> ffmpeg  ffmpeg2theora  libffmpegthumbnailer-dev \
> libavcodec-dev  libavformat-dev \
> libxmu-dev  libswscale-dev
> Nikos
