[GRASS-user] Add command layer problem
    Martin Landa
    landa.martin at gmail.com
    Wed Nov 14 09:08:18 PST 2012
2012/11/14 Aldo Clerici <aldo.clerici at unipr.it>:
> Surely due to my scarce practice with the wxpython GUI
> (grass-6.4.svn_src_snapshot_2012_09_15) I’m not able to insert a command in
> the Layer Manager tree. I click the ‘Add grid or vector labels overlay’
> button in the Layer Manager, then the ‘Add command layer’ option. A blank
> layer is added in the Layer Manager. I type the command, for example d.rast
> geology (Spearfish data), in the layer, then Enter, but the map is not
> displayed in the Map Display, not even by using the Display and Render
> buttons (the Render option is on anyway) .  Where did I go wrong?
command map layer is something like artefact from TCL/TK GUI and not
really used by most of users I would guess. You need to type the name
of the first parameter, so `d.rast map=geology`. This should be fixed
in r53811 (6.4.3svn), where `d.rast geology` should work. Testing
welcomed.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
