[GRASS-user] error in g.extension
Gianluca Massei
agr.gianluca.massei at gmail.com
Sat Nov 17 04:44:40 PST 2012
I'm sorry I've sent the message "too many" times in the list! %-(
> Are you the owner of the mapset?
Yes, I'm owner of the mapset. With ls -l -a I've this:
drwxrwxrwx 6 gianluca gianluca 4096 nov 6 21:58 UmbriaRoma40
I've used g.extension from command line.
I've the same problem in grass 6.4
Thanks for the help
2012/11/17 Markus Neteler <neteler at osgeo.org>
> On Fri, Nov 16, 2012 at 10:53 PM, Gianluca Massei
> <agr.gianluca.massei at gmail.com> wrote:
> > Hi,
> > I'm trying to install some extension in grass 7 (compiled from svn
> > grass_trunk code in ubuntu 12.10) but I get this message for all my
> tests:
> > ERROR: MAPSET PERMANENT - permission denied
> > make: *** [v.surf.icw.tmp.html] Errore 1
> > rm v.surf.icw.tmp.html
> > ERROR: Compilation failed, sorry. Please check above error messages.
> > I can't understand why the "permission is denied" in MAPSET PERMANENT:
> I've
> > set all files and folders with "chmod 777 *" and my
> > $GRASS_ADDON_BASE=/home/gianluca/.grass7/addons.
> Do you use the wxGUI integrated extension manager or "g.extension" (as
> the subject states)?
> Markus
Dott. Gianluca Massei, PhD
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121117/6b854133/attachment.html>
