[GRASS-user] error in g.extension
王德辉 dehuiw at gig.ac.cn
Sat Nov 17 06:02:36 PST 2012
If you only want to use this addon, then you just need to download the addon and run the command " sudo make MODULE_TOPDIR=/usr/local/grass-7.0.svn/" in the addon folder.
dehui
> -----原始邮件-----
> 发件人: "Markus Neteler" <neteler at osgeo.org>
> 发送时间: 2012年11月17日 星期六
> 收件人: "Gianluca Massei" <agr.gianluca.massei at gmail.com>
> 抄送: "GRASS user list" <grass-user at lists.osgeo.org>
> 主题: Re: [GRASS-user] error in g.extension
> On Fri, Nov 16, 2012 at 10:53 PM, Gianluca Massei
> <agr.gianluca.massei at gmail.com> wrote:
> > Hi,
> > I'm trying  to install some  extension in grass 7 (compiled from svn
> > grass_trunk code in ubuntu 12.10) but I get this message for all my tests:
> > ERROR: MAPSET PERMANENT - permission denied
> Are you the owner of the mapset?
> > make: *** [v.surf.icw.tmp.html] Errore 1
> > rm v.surf.icw.tmp.html
> > ERROR: Compilation failed, sorry. Please check above error messages.
> > I can't understand why the "permission is denied" in MAPSET PERMANENT: I've
> > set all files and folders with "chmod 777 *" and my
> > $GRASS_ADDON_BASE=/home/gianluca/.grass7/addons.
> Do you use the wxGUI integrated extension manager or "g.extension" (as
> the subject states)?
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121117/8a37058b/attachment.html>
