[GRASS-user] error in g.extension
Nikos Alexandris nik at nikosalexandris.net
Thu Nov 22 01:59:55 PST 2012
王德辉:
> Hi Nikos,
Hi!
> My grasssvns(7,6.5,6.4) and grass-addons are all in /usr/local/ folders,
you should grant rwx access to the respective directory(-ies)
 > so the compiling...
...will and should not be required to be executed as a super-user
> ...and installing command need the super user permission,
the installation yes, it is probably required since stuff are copied in
"restricted" directories
> if not, the installations will be failed.
> For example, I use the following
> command to install all the grass7-addons: cd
> /usr/local/grass-addons/grass7;sudo make
> MODULE_TOPDIR=/usr/local/grass-7.0.svn/ Best regards,
Here also, my guess is that you do not need _sudo_.
Nikos
