[GRASS-user] error in g.extension
王德辉 dehuiw at gig.ac.cn
Thu Nov 22 01:11:18 PST 2012
Hi Nikos,
My grasssvns(7,6.5,6.4) and grass-addons are all in /usr/local/ folders, so the compiling and installing command need the super user permission, if not, the installations will be failed. For example, I use the following command to install all the grass7-addons:
cd /usr/local/grass-addons/grass7;sudo make MODULE_TOPDIR=/usr/local/grass-7.0.svn/
Best regards,
dehui
在2012-11-21 15:56:15,王德辉<dehuiw at gig.ac.cn>写道:
> 王德辉:
> > If you only want to use this addon, then you just need to download the addon
> > and run the command " sudo make MODULE_TOPDIR=/usr/local/grass-7.0.svn/" in
> > the addon folder.
> Dehui,
> Of course I don't know how you have setup your operating systems environment
> variables and other details.  Yet, I would like point out (actually repeat)
> that one shouldn't compile, e.g. use the make command, as a super-user.
> Inside a directory whose permissions grant read and write access to a user,
> the use of sudo is not/should not be required.  Furthermore, I am not sure if
> there are/will be other implications -- probably not.  But still, it is not a
> good practice.
> The reason that  sudo  is required for the installation step, is of course
> that the process itself copies files in "privileged" directories.  Without
> sudo  the installation would fail.
> However, in case you know why you use  sudo  while compiling,  I kindly ask
> you to share some details.  I would like to know -- since I too was told, in
> the past, that doing "sudo make"  is not required (maybe not correct).
> All the best, Nikos
> [rest deleted]
