[GRASS-user] Spectral Unmixing
Mohammed Rashad
mohammedrashadkm at gmail.com
Tue Nov 27 18:37:45 PST 2012
fine.
If i give input map and the corresponding output map from i.spec.unmix. can
you evaluate?
Also do you see any problem in my selection of input maps?
which are available in grass sample dataset (nc_spm_08) landat (mapset)
On Wed, Nov 28, 2012 at 2:26 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Rashad,
> On Tue, Nov 27, 2012 at 9:11 PM, Mohammed Rashad
> <mohammedrashadkm at gmail.com> wrote:
> > Hi Markus,
> > These is the error i got from spectral unmixing module
> maybe I was not clear: the module is currently non functional
> and needs to be updated and modernized. I write it in 1998/99
> as part of my master thesis for GRASS 5.
> > GRASS 6.3.1svn (nc_spm_08):~ > i.spec.unmix
> The 6.3 version which I sent to use was partially updated by
> Brad Douglas (if I recall correctly) to GRASS 6 but not in a
> complete stage. So the order would be
> - get it running in 6.3 as you try;
> - while keeping GRASS 7 in mind (jump over 6.4) which may
> simplify some code structures.
> The update "train" was:
> * GRASS 5: i.spec.unmix: working with MESHACH numerical libs
> (http://www.netlib.org/c/meschach/readme)
> * GRASS 6.3: attempt to rewrite the MESHACH support to LAPACK
> support since the MESHACH library wasn't clear.
> This remained unfinished by me.
> * Someone (Brad?) took over to complete this but didn't fully finish.
> This version you are trying right now.
> Now we are at GRASS 7 and it is time to get i.spec.unmix up and
> running :)
> Best,
> Markus
Regards,
Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121128/dafead24/attachment.html>
