[GRASS-user] Parallel GRASS jobs .....
    Sylvain Maillard
    sylvain.maillard at gmail.com
    Wed Nov 28 01:56:38 PST 2012
for this approach, the best would be to
(before the multi-process job)
- put your map into the PERMANENT mapset
(for each process in parallel)
- make a new mapset for each process
- define the region of each mapset as a chunk of the whole region
- make your calculation
(once the process competed)
- put together all the results (eg, with r.patch)
Sylvain
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121128/454c6b07/attachment.html>
