[GRASS-user] Parallel GRASS jobs .....
Andranik Hayrapetyan andranik.h89 at gmail.com
Wed Nov 28 02:13:01 PST 2012
I have been trying something like this some time ago, but I could not
define region of a mapset as chunk of the whole region.
I was trying to do that with g.region, but it only resized my map and
didn't "cut" it.
Is g.region the right tool for this task?
If it is not difficult for you, can you, please, explain the process of
 doing  " *define the region of each mapset as a chunk of the whole region* "
a bit more detailed.
On Wed, Nov 28, 2012 at 1:56 PM, Sylvain Maillard <
sylvain.maillard at gmail.com> wrote:
> Hi,
> for this approach, the best would be to
> (before the multi-process job)
> - put your map into the PERMANENT mapset
> (for each process in parallel)
> - make a new mapset for each process
> - define the region of each mapset as a chunk of the whole region
> - make your calculation
> (once the process competed)
> - put together all the results (eg, with r.patch)
> Sylvain
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121128/f544f46b/attachment-0001.html>
