[GRASS-user] Parallel GRASS jobs .....
Andranik Hayrapetyan
andranik.h89 at gmail.com
Wed Nov 28 23:51:35 PST 2012
Just one more question.
Now that I have, for example, 4 mapsets with different parts of the main
map, and the calculation is done, how can I "see" this parts of map from
one mapset (e.g. from PERMANENT) , to gather them together with r.patch ?
Is there a way to do this without exporting maps from each mapset and then
importing them again into one mapset?
May be there is a way to change permissions so that PERMANENT could see all
maps in other mapsets?
On Thu, Nov 29, 2012 at 11:36 AM, Andranik Hayrapetyan <
andranik.h89 at gmail.com> wrote:
> Dear all,
> Thank you very very much for your help!!!
> I did it!
> *Daniel , *your detailed explanations were very useful, thank you!
> P.S. I am using the GUI just to clearly understand the procedure. Now I
> will try to make scripts that will do this job.
> Regards,
> Andranik
> On Thu, Nov 29, 2012 at 2:46 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Wed, Nov 28, 2012 at 4:25 PM, Michael Barton <Michael.Barton at asu.edu>
>> wrote:
>> > The computational region (i.e., not the display region in the GUI) is
>> the
>> > rectangular section of the world where GIS operations take place.
>> For this, see also here:
>> http://grasswiki.osgeo.org/wiki/Computational_region
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121129/d3653bec/attachment-0001.html>
