[GRASS-user] Spectral Unmixing
    Mohammed Rashad
    mohammedrashadkm at gmail.com
    Fri Nov 30 07:52:36 PST 2012
Thanks. I am glad that results looks fine. BTW, I have write access to
grass addons svn. So Can I commit the code by myself ?
If so I will do it by monday evening. I had sent another mail to you
i.spec.unmix [new output]
And for the record it has been ported to grass7 today.
see more info below.
*i.spec.unmix group=group2 at landsat result=res error=err iter=iter
matrix=/home/rashad/dev/sample/spectrum.dat*
Dataset: *nc_spm_08*
Mapset: *landsat*
group2 at landsat
*<lsat5_1987_10 at landsat>    <lsat5_1987_20 at landsat>    *
*<lsat5_1987_30 at landsat>    <lsat5_1987_40 at landsat>    *
*<lsat5_1987_50 at landsat>    <lsat5_1987_60 at landsat>    *
*Output Files(created):*
Results: res.1, res.2, res.3, res.4
Iteration: iter
Error: err
I hope results are pretty much similar here
*Attached Files*
res.1png screenshot of raster map (res.1)
will attach screenshot of other outputs maps if needed
On Fri, Nov 30, 2012 at 7:42 PM, Markus Neteler <neteler at osgeo.org> wrote:
> hi Rashad,
> On Thu, Nov 29, 2012 at 7:52 PM, Mohammed Rashad
> <mohammedrashadkm at gmail.com> wrote:
> > I am getting some output from i.spec.unmix which uses gmath and some data
> > structures from meschach
> > Please find below screenshot and notes of the spectral unmixing output.
> > Could you please verify it and let me know.
> this looks really very promising!
> Of course the results depend a lot on the input spectra which are
> sometimes not easy to obtain. You need to identify pure pixels
> which one can find the the corners of the PCA featurespace. When
> time, I can translate my German instructions to English.
> > Code works in grass 6.4(release), grass 6.5(grass6_devel), grass
> > 6.3(release)
> Wonderful.
> For the GRASS 6 version, could you please update or patch against
> grass-addons/grass6/imagery/i.spec.unmix/
> > If outputs are fine I will port to grass7
> Great!
> Thanks for your hard work,
> Markus
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121130/ce4cfdb0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121130/ce4cfdb0/attachment-0001.png>
