[GRASS-user] Can't load Grass 7 on Windows 7
Filipe Dias
filipesdias at gmail.com
Mon Oct 1 13:41:08 PDT 2012
Sorry for my ignorance on the subject, but what do you mean by *" run
"make" within the directory and check for the error"* ?
Meanwhile I tried reinstalling and uninstall/install Grass 7 and I still
get the same error. If its a local problem shouldn't that have solved the
problem?
Thanks
Best regards
F.
On Mon, Oct 1, 2012 at 6:41 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Sep 30, 2012 at 3:29 PM, Filipe Dias <filipesdias at gmail.com>
> wrote:
> > Hi,
> > I just installed Grass 7 via osgeo4w on W7 64 bits and got this error
> after
> > pressing "Start Grass".
> > 3d view mode: grass_g3d.7.0.svn not found
> > Grass module g.region not found. Unable to star map display window
> The package is coming from here:
> http://wingrass.fsv.cvut.cz/grass70/osgeo4w/
> In fact, there is a compilation error:
> http://wingrass.fsv.cvut.cz/grass70/logs/log-r53294-363/error.log
> --> /osgeo4w/usr/src/grass_trunk/lib/raster3d
> Someone having a local Windows compile environment will need
> to run "make" within the directory and check for the error. The
> other errors will be mainly subsequent errors.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121001/f33a4a44/attachment.html>
