[GRASS-user] v.in.ascii error: bad type reading source file
Rich Shepard
rshepard at appl-ecosys.com
Fri Oct 5 12:50:13 PDT 2012
On Fri, 5 Oct 2012, Helmut Kudrnovsky wrote:
> change the order of the coordinates
> this is imported here in following location:
> -PROJ_INFO-------------------------------------------------
> proj : ll
> datum : wgs84
> ellps : wgs84
> no_defs : defined
> -PROJ_UNITS------------------------------------------------
> unit : degree
> units : degrees
> meters : 1.0
Here, it's:
proj: ll
datum: nad83
ellps: grs80
towgs84: 0,0,0,0,0,0,0
no_defs: defined
unit: degree
units: degrees
meters: 1.0
and the results with the re-ordered attributes:
v.in.ascii -n
in='/home/rshepard/projects/nevada/queenstake/sites-data/biosites.csv'
out=biosites format=standard col='x double precision, y double precision, y
double precision', x=1 y=2 cat=0 --o
WARNING: Vector map <biosites> already exists and will be overwritten
ERROR: Error reading ASCII file: (unknown type)
[-115.99418333|41.42188333|'SC-100']
It must be something simple that I'm doing incorrectly when I used to not
make this mistake.
Thanks,
Rich
