[GRASS-user] Hyperindex map for genaration of ATLAS, Volume of Water/Earth with reference to a user stated depth datum, Genarate dip/strike from the DEM model
SWAPAN GHOSH
swap.ghsh at gmail.com
Wed Oct 10 04:58:37 PDT 2012
Dear Markus,
Thank you very much. I can solve the problem as per your advice.I have also
small request to you that how I can solve the below four problem like-
- Reading hyperspectral image and then convert it into Grass GIS format.
- BitMap(Color,Mono and grey scale bitmap back ground)
- Cut and Fill from two DEM
- Statistical properties from the DEM using user specified polygon on a
specified area of a river
Thanks & Regards,
Swapan Ghosh
On Wed, Oct 10, 2012 at 12:23 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 10, 2012 at 8:30 AM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> > Dear all,
> > Any one please guide me how I can solve the problem like- " 1. Hyperindex
> This driver may help:
> http://grass.osgeo.org/gdp/html_grass64/htmlmapdriver.html
> > 2. Volume of Water/Earth with reference to a user stated depth datum,
> See
> http://grass.osgeo.org/gdp/html_grass64/r.volume.html
> Alternative: work with voxels, then
> http://grass.osgeo.org/gdp/html_grass64/r3.stats.html
> > 3. Genarate dip/strike from the DEM model "
> See:
> http://grass.osgeo.org/gdp/html_grass64/r.plane.html
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121010/bdb19f1e/attachment.html>
