[GRASS-user] Hyperindex map for genaration of ATLAS, Volume of Water/Earth with reference to a user stated depth datum, Genarate dip/strike from the DEM model
Moritz Lennert mlennert at club.worldonline.be
Wed Oct 10 05:52:41 PDT 2012
On 10/10/12 13:58, SWAPAN GHOSH wrote:
> Dear Markus,
> Thank you very much. I can solve the problem as per your advice.I have
> also small request to you that how I can solve the below four problem like-
> - Reading hyperspectral image and then convert it into Grass GIS format.
Depends on the formet, but always try first with r.in.gdal.
> - BitMap(Color,Mono and grey scale bitmap back ground)
Not sure I understand what you are looking for here.
> - Cut and Fill from two DEM
r.patch
> - Statistical properties from the DEM using user specified polygon on a
> specified area of a river
v.rast.stats.
Moritz
