[GRASS-user] Using r.out.kml and scripts in Windows Binary- error
António Rocha antonio.rocha at deimos.com.pt
Wed Sep 12 09:32:29 PDT 2012
Greetings
I have used in Linux the r.out.kml script. Now, I hava installed Grass
GIS (WinGRASS-6.4.2-2-Setup.exe) in Windows and I have placed my
r.out.kml file in scripts folder and created a r.out.kml.bat file (with
the path to the file) in bin folder. When I write r.out.kml in command
console I get:
   File "C:\GRASS642\etc\wxpython\gui_modules\prompt.py",
line 1105, in OnKeyPressed
self.parent.RunCmd(cmd)
   File "C:\GRASS642\etc\wxpython\gui_modules\goutput.py",
line 523, in RunCmd
task = menuform.GUI(show = None).ParseCommand(command)
   File "C:\GRASS642\etc\wxpython\gui_modules\menuform.py",
line 1732, in ParseCommand
blackList = _blackList)
   File "C:\GRASS642\etc\python\grass\script\task.py", line
460, in parse_interface
tree = etree.fromstring(get_interface_description(name))
   File "C:\GRASS642\Python27\lib\xml\etree\ElementTree.py",
line 1283, in XML
return parser.close()
line 1636, in close
self._raiseerror(v)
line 1488, in _raiseerror
raise err
xml.etree.ElementTree
ParseError
no element found: line 1, column 0
When I try to run other scripts (e.g. v.report) I get also this error:
line 523, in RunCmd
line 1283, in XML
line 1636, in close
self._raiseerror(v)
raise err
ParseError
What shall be done? Shall I downgrade to a previous vertsion?
Thanks
Antonio
