[GRASS-user] Using r.out.kml and scripts in Windows Binary-	error
    Helmut Kudrnovsky
    hellik at web.de
    Wed Sep 12 11:13:27 PDT 2012
>Now, I hava installed Grass
>GIS (WinGRASS-6.4.2-2-Setup.exe) in Windows and I have placed my
>r.out.kml file in scripts folder and created a r.out.kml.bat file (with
>the path to the file) in bin folder. When I write r.out.kml in command
>console I get:
>When I try to run other scripts (e.g. v.report) I get also this error:
>Traceback (most recent call last):
>   File "C:\GRASS642\etc\wxpython\gui_modules\prompt.py",
>line 1105, in OnKeyPressed
tried here with osgeo4w-WinGRASS-6.4.2, v.report works:
v.report map=firestations at PERMANENT option=coor
Zeige Typ/Name der Spalten der Datenbank des Layers 1:
cat|ID|LABEL|LOCATION|CITY|MUN_COUNT|PUMPERS|PUMPER_TAN|TANKER|MINI_PUMPE|RESCUE_SER|AERIAL|BRUSH|OTHERS|WATER_RESC|MUNCOID|BLDGCODE|AGENCY|STATIONID|RECNO|CV_SID2|CVLAG|x|y|z
1|24|Morrisville #3|6804 Carpenter Fire Station
Rd|Morrisville|M|0|3|0|0|0|0|1|0|0|1|240|FD|MF3A|1|MF3A|1.4|620856.958587634|230066.383132105|0
- can you try it in the osgeo4w-WinGRASS-6.4.2?
- do you have more than one python in your system?
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/Using-r-out-kml-and-scripts-in-Windows-Binary-error-tp5001496p5001508.html
Sent from the Grass - Users mailing list archive at Nabble.com.
