[GRASS-user] Using r.out.kml and scripts in Windows Binary- error
António Rocha
antonio.rocha at deimos.com.pt
Thu Sep 13 02:44:05 PDT 2012
Hello Martin
I tried from the command line in the GUI.
Ok next time I will give a try with that extension. Thanks
On 13-09-2012 10:40, Martin Landa wrote:
> Hi,
> 2012/9/13 António Rocha <antonio.rocha at deimos.com.pt>:
>> I tried to install r.out.kml with g.extension but I got this error:
>> which: svn: unknown command
>> ERROR: svn client required. Please install Subversion first.
>> (maybe it is relevant to indicate that in the help file and a few links to
>> Subversion clients)
> have you tried to install extension from command line or wxGUI [1]?
> wxGUI uses another g.extension (Python based) which should download on
> Windows directly prepared binaries.
> Martin
> [1] http://grass.osgeo.org/wiki/WxGUI#Extension_Manager
António Rocha
Earth Observation Applications and Services
Av. D. João II, Lt 1.17.01 - 10º, Ed. Torre Zen
1998-023 Lisboa, Portugal
Ph: +351 21 893 30 23
Fax: +351 21 896 90 99
http://www.deimos.pt
