2012/9/13 António Rocha <antonio.rocha at deimos.com.pt>: > I tried from the command line in the GUI. > Ok next time I will give a try with that extension. Thanks you can use from wxGUI CLI `g.extension.py` (note `py` extension). Martin -- Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
