[GRASS-user] data format changing
Markus Neteler
neteler at osgeo.org
Tue Sep 18 06:23:24 PDT 2012
On Mon, Sep 17, 2012 at 2:45 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Sep 17, 2012 at 7:14 AM, 巩哲 <gongzhe79 at gmail.com> wrote:
>> Then I need a binary image
> What do you mean with "binary map"? Which format would you like to use?
>From the offlist indication you gave, I see that only 8-bit unsigned integer,
16-bit signed integer or 32-bit signed real data are supported by that software.
Hence I would multiply the NDVI values in GRASS with 100.0 (r.mapcalc)
and then export with r.out.bin to integer.
Markus
