[GRASS-user] data format changing
Markus Neteler
neteler at osgeo.org
Mon Sep 17 05:45:13 PDT 2012
On Mon, Sep 17, 2012 at 7:14 AM, 巩哲 <gongzhe79 at gmail.com> wrote:
> Hi,I had met some problems about data format.
> Firstly,I imported SPOTVGT NDVI file into GRASS, by using i.in.spotvgt,
> the data range is -0.96~0.92 (already resampled by r.mapcalc).
Yes, this is within the NDVI range.
> Then I need a binary image
What do you mean with "binary map"? Which format would you like to use?
> for analyzing in another software,so I exported
> the map by using r.out.bin -ib input=XXXXX,output=XXXXX,then a 16 bit binary
> image was created, but the data value became only 0 or 1.
You requested an integer map
http://grass.osgeo.org/grass64/manuals/html64_user/r.out.bin.html
so values in the range of -1 ... +1 are mapped into -1,0,1.
> So when and where
> should I change the data format by using what command?
To share data with other software packages, likely r.out.gdal is the better
option to export to common GIS formats.
Markus
