[GRASS-user] FW: r.out.xyz: Output error
Stephen Brearley mail at stephenbrearley.name
Mon Apr 1 02:41:41 PDT 2013
Hi Helmut
Not clear what you mean by separator. Recognise '|' as the pipe symbol in
Unix. I'm running Windows, and the module enters a ' ' (space) or I do this
manually when I type in the command. Note that the '@' symbol seems to have
got changed to ' AT ' by the parser. Tried manually typing the command with
'@' instead of ' AT ' all this and get the same result.
Is this a bug, and could it be present in other modules, say if the code has
been copied and pasted, since 'output' is a rather common parameter?
Do we have a fix?
Thanks
  Stephen
-----Original Message-----
Sent: 30 March 2013 21:40
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] r.out.xyz: Output error
>if the separator is given manually instead the default one, r.out.xyz
works:
it seems given Default: | breaks the script, because also manually given |
stopps the script...
best regards
Helmut
View this message in context:
http://osgeo-org.1560.n6.nabble.com/r-out-xyz-Output-error-tp5043808p5043821
.html
Sent from the Grass - Users mailing list archive at Nabble.com.
