[GRASS-user] FW:  r.out.xyz: Output error
    Helmut Kudrnovsky
    hellik at web.de
    Mon Apr  1 05:35:50 PDT 2013
>Not clear what you mean by separator.
have a look at the manual:
http://grass.osgeo.org/grass70/manuals/r.out.xyz.html
separator=character
    Field separator
    Special characters: newline, space, comma, tab
    Default: |
> I'm running Windows,
tested here with
GRASS version: 7.0.svn
GRASS SVN Revision: 55573
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
> Is this a bug,
see
http://lists.osgeo.org/pipermail/grass-user/2013-March/067602.html
r.out.xyz input=elevation at ERMANENT output=J:\wd\routxyz\test2.csv
separator=,
(Sat Mar 30 22:26:32 2013) Command finished (3 sec)
r.out.xyz input=elevation at PERMANENT output=J:\wd\routxyz\test3.csv
separator=;
(Sat Mar 30 22:28:00 2013) Command finished (2 sec)
please try another separator (e.g. ; or , or you can also type
separator=space) with your data
>say if the code has
>been copied and pasted, since 'output' is a rather common parameter?
it seems that 'output' isn't the problem, but the seperator...
>Do we have a fix?
please test on your platform with  a sample data set
(http://grass.osgeo.org/download/sample-data/)
and the example from the manual
(http://grass.osgeo.org/grass70/manuals/r.out.xyz.html)
and when it fails, open a bug ticket
(http://trac.osgeo.org/grass/)
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/FW-r-out-xyz-Output-error-tp5043895p5043903.html
Sent from the Grass - Users mailing list archive at Nabble.com.
