[GRASS-user] GRASS 6.4 How to extract point-values from multiple rasters
Werner Macho
werner.macho at gmail.com
Thu Apr 4 07:48:57 PDT 2013
ups my fault - did not read the full link by myself .. *blush* seems that
ArcGIS is needed for the "lookalike" bash script ;)
but anyway the other links should give you enough information too ..
HTH
Werner
On Thu, Apr 4, 2013 at 4:44 PM, Werner Macho <werner.macho at gmail.com> wrote:
> Hi!
> I recently had nearly the same problem .. and solved it in different GIS
> Applications .. (there were not so many points i needed) but during
> research I found this link
> http://gis.stackexchange.com/questions/3538/extract-raster-values-at-points
> Which you might find interesting especially when looking at
> isectpntrst(in="path/to/shapefile", raster="path/to/raster",
> field="fieldname")
> when it comes to bash ..
> or probably
> http://gis-techniques.blogspot.co.at/2012/10/extract-raster-values-from-points.html
> using R ..
> It always depends how you'd like to solve it .. of course it can be done
> in GRASS too ..
> hope this helps
> kind regards
> Werner
> On Thu, Apr 4, 2013 at 4:37 PM, BLANDENIER Lucien <
> lucien.blandenier at unine.ch> wrote:
>> Dear GRASS community,
>> I have to extract isolated value from several raster.
>> I've found this script but I do not understand how to run it. Would
>> someone have an other script with more comments (notably what are the input
>> I have to give, what are the grass or python function/module) or explain me
>> how to run this script.
>> I would also be interested by a bash script if someone has such a script.
>> Thank you for your support.
>> Kind regards
>> Lucien
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- n�chster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130404/3c7da51e/attachment.html>
