[GRASS-user] Raster classification by typical methods?
Timmie
timmichelsen at gmx-topmail.de
Thu Apr 4 09:48:25 PDT 2013
> Those two are equivalent. And can be done with a little r.mapcalc math
> or with r.recode rules (which you can embed in a script if you need to
> calculate the intervals on the fly.
What is the reason for not having this implemented in GRASS directly?
Design considerations?
I am looking for raster classification in equvalents to
* Equal Interval
* Quantile (OK, see below)
* Natural Breaks (Jenks)
* Standard Deviation
* Pretty Breaks
Note: OSGEO4W does not install R.
> > * automatically classification based on defined number of classes
> You can use r.quantile for quantile classification:
> r.quantile elevation quantiles=5 -r --quiet | r.recode elevation
> out=elev_quant5 rules=-
How do I get "|" pipe in the GUI on OSGEO4W?
I got a strange output using the example from the handbook:
r.quantile -r --q input=RASTER_fullrange percentiles=0.2,0.4,0.6,0.8
900.000000:900.000000:1
900.000000:900.000000:2
900.000000:900.000000:3
900.000000:900.000000:4
900.000000:2000.000000:5
What is wrong here?
And when I use the quanitles I get anther strange:
r.quantile -r --quiet input=RASTER_fullrange quantiles=4
1120.000000:1120.000000:1
2120.000000:1340.000000:2
1340.000000:1560.000000:3
1560.000000:2000.000000:4
-> Why does ot not set class 1 to
900.000000:1120.000000:1
900 is the minimum value.
Thanks a lot in advance,
Timmie
