[GRASS-user] Compile python add-on with GRASS7 - HTML/man error?
Markus Neteler
neteler at osgeo.org
Tue Apr 9 04:48:28 PDT 2013
On Tue, Apr 9, 2013 at 11:58 AM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi,
> I try to compile a GRASS6 add-on with GRASS7 to adapt the code to
> the new GRASS version. I know probably some or even more code lines
> have to be adapted for the new version, however I already fail when I want
> to compile it with GRASS 7:
> Errors in:
> /usr/local/src/grass7_trunk/scripts/r.fidimo
> Error (KeyError(None,)): <DT><b>outflow_point</b></DT>
> it seems there is a problem with the html-manual file?
Yes.
In r55671 I have removed a series of HTML bugs + broken long
lines. Now it compiles.
Note that GRASS 6 is more HTML fault tolerant (unfortunately). Hence
http://validator.w3.org/
may be used.
