[GRASS-user] Compile python add-on with GRASS7 - HTML/man error?
Johannes Radinger
johannesradinger at gmail.com
Tue Apr 9 05:05:31 PDT 2013
Thanks Markus, and thank you for the hint with the validator...
On Tue, Apr 9, 2013 at 1:48 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Apr 9, 2013 at 11:58 AM, Johannes Radinger
> <johannesradinger at gmail.com> wrote:
> > Hi,
> > I try to compile a GRASS6 add-on with GRASS7 to adapt the code to
> > the new GRASS version. I know probably some or even more code lines
> > have to be adapted for the new version, however I already fail when I
> want
> > to compile it with GRASS 7:
> > Errors in:
> > /usr/local/src/grass7_trunk/scripts/r.fidimo
> > Error (KeyError(None,)): <DT><b>outflow_point</b></DT>
> > it seems there is a problem with the html-manual file?
> Yes.
> In r55671 I have removed a series of HTML bugs + broken long
> lines. Now it compiles.
> Note that GRASS 6 is more HTML fault tolerant (unfortunately). Hence
> http://validator.w3.org/
> may be used.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130409/1083ccbf/attachment.html>
