[GRASS-user] Python placeholder (%d) in stdin statement of db.execute
Markus Metz markus.metz.giswork at gmail.com
Thu Apr 11 02:15:14 PDT 2013
On Thu, Apr 11, 2013 at 8:58 AM, Hamish <hamish_b at yahoo.com> wrote:
> Johannes wrote:
>> I just tested it again and realized this problem is
>> not related to the placeholder in the python code,
>> but probably an other issue of my pythoncode line
>> nothing is update when use:
>> grass.write_command("db.execute", stdin = "UPDATE my points
>>   SET prob=100")
>> but using UPDATE my points SET prob=100 in the module GUI
>> works as mentioned  already before.
>> Has anyone experience in using db.execute in python with
>> standard input in GRASS7?
> in GRASS7 you need to add "input=-" as an option to trigger
> reading input stdin. (or else stalled module gui headaches..)
> perhaps this needs to be changed to YES?
>     input->required = NO;
No, because db.execute sql=<SQL statement> works just fine, input is
not required.
Markus M
