[GRASS-user] Number of centroids outside area: difficulty with cleaning
RichardC
richtcooper at hotmail.com
Sun Apr 14 02:02:01 PDT 2013
I'm trying to remove a 'Number of centroids outside area' after
re-projecting a file.
I've tried v.clean with various tools. including breaklines/boundaries,
break polygons, snap lines/boundaries.
The intial imported shapefile did not display any errors, but the following
errors appeared on re-projecting the latter file:
Building topology for vector map <as_bas_shp>...
Registering primitives...
44546 primitives registered
1680359 vertices registered
Building areas...
13602 areas built
2828 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 33748
Number of primitives: 44546
Number of points: 0
Number of lines: 0
Number of boundaries: 30931
Number of centroids: 13615
Number of areas: 13602
Number of isles: 2828
*Number of centroids outside area: 13
Number of duplicate centroids: 108
Number of areas without centroid: 108*
I can remove the duplicate centroids with v.clean (using bpol) but not the
centroids outside area.
What would be the easiest way to remove, or at least to identify (filter
for) and manually assess?
I've also tried outputting the errors using the error= command, but no
geometries are visible in the latter.
Cheers,
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/Number-of-centroids-outside-area-difficulty-with-cleaning-tp5046717.html
Sent from the Grass - Users mailing list archive at Nabble.com.
