[GRASS-user] installing add-ons for GRASS 6.4.2 on Ubuntu fails
G. Allegri
giohappy at gmail.com
Tue Apr 16 12:44:02 PDT 2013
I've compiled GRASS 6.4.3RC2.
The add-on installation exits with the following error:
/usr/bin/install: impossibile eseguire stat di "/home/giova/
Data/GRASSDB/3003/PERMANENT/.tmp/xubuntu/16152.0/v.mkhexgrid
/man/man1/v.mkhexgrid.1": File o directory non esistente
make: *** [install] Errore 1
WARNING: Installation failed, sorry. Please check above error messages.
In english it's something like
/usr/bin/install: cannot execute stat "/home/giova/
/man/man1/v.mkhexgrid.1": File or folder not existing
make: *** [install] Error 1
I've installed system wide with sudo, but I launch GRASS without sudoing.
Could the problem be related to this?
giovanni
2013/4/16 G. Allegri <giohappy at gmail.com>
> I will go on compiling.
> I'm not so expert in sw management on Linux, will it be problematic to
> have both a 6.4 and 7 GRASS on the same machine? I would like to test GRASS
> 7 too...
> giovanni
> 2013/4/16 Markus Neteler <neteler at osgeo.org>
>> On Mon, Apr 15, 2013 at 12:32 PM, G. Allegri <giohappy at gmail.com> wrote:
>> > Hi,
>> > I've never installed add-ons throught the WxPython GUI.
>> > I need to use the v.mkhexgrid [1], but the process fails because at some
>> > stage (Rules.make) it tries to create/write into /usr/lib/bin folder
>> (very
>> > strange).
>> You need (to wait for) current GRASS 6.4.svn or 6.4.3 which hopefully
>> addresses this problem.
>> The best would be that you compile 6.4.svn yourself on Ubuntu and
>> make a test before we release 6.4.3:
>> http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
>> thanks
>> Markus
> Giovanni Allegri
> http://about.me/giovanniallegri
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130416/6a1ad95a/attachment.html>
