[GRASS-user] FreeBSD-Grass7 can't start
    Martin Landa
    landa.martin at gmail.com
    Wed Apr 17 09:58:21 PDT 2013
2013/4/17 Pierre Stévens <pierre at geobsd.com>:
>   File "/usr/local/bin/grass70", line 659, in load_env
>     if not os.access(grass_env_file, os.R_OK):
> TypeError: coercing to Unicode: need string or buffer, NoneType found
initial script needs to be updated for FreeBSD. In r55856, I added
warning for unsupported shell. In this case `bashrc` env file is used
by default.
What shell do you have [1]?
Martin
[1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py?rev=55856#L762
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
