[GRASS-user] ZSH Shell
Pierre Stévens pierre at geobsd.com
Thu Apr 18 02:29:06 PDT 2013
I use Z-Shell.
Next to your mail, I've edited '/usr/local/bin/grass70' :
1. Line 783 :
	elif sh="zsh":
		shellname = "Z Shell"
2. Line 792:
	elif sh in ['zsh']:
        grass_env_file = os.path.join(grass_config_dir, 'zshrc')
And Grass70 starts perfectly on FreeBSD with ZSH.
Thank you Martin.
Note : ZSH must be install from ports.
Hence, it is available from '/usr/local/bin/zsh'.
It's not the case with SH,CSH or TCSH which are located in '/bin/'.
The '/etc/shells' file lists all shells available on system.
Some ports (like GIT or ZSH) edit this file automatically.
On Wed, Apr 17, 2013 at 06:58:21PM +0200, Martin Landa wrote:
> Hi,
> 2013/4/17 Pierre Stévens <pierre at geobsd.com>:
> >   File "/usr/local/bin/grass70", line 659, in load_env
> >     if not os.access(grass_env_file, os.R_OK):
> > TypeError: coercing to Unicode: need string or buffer, NoneType found
> initial script needs to be updated for FreeBSD. In r55856, I added
> warning for unsupported shell. In this case `bashrc` env file is used
> by default.
> What shell do you have [1]?
> Martin
> [1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py?rev=55856#L762
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
