[GRASS-user] r.sun use - automaticcaly stopped process ?
simogeo
simon.georget at gmail.com
Thu Apr 18 05:57:00 PDT 2013
hamish-2 wrote
> a Seg. Fault happens due to programmer error, they told the
> program to write memory outside of where it should have. A
> seg fault should not normally happen due to an out-of-memory
> error.
> when a program eats up all the system memory, the OS is left
> which a choice of what to do, as it needs memory too, and the
> choice it makes is to protect itself and kill the process which
> is eating up all the memory. I'm not sure what the translation
> would look like, for me I think it's like "Process killed."
Thanks for the precision. Indeed, it should be "process killed".
hamish-2 wrote
> try watching the process in `top` in a Terminal window to
> see how much memory it uses, and keep going and try changing
> the region res= to be as coarse as 5m.
I haven't seen the memory usage going to 100%, but it should be the cause,
indeed since it's working with a lower resolution (for example region
res=2).
This issue is /kind of solved/ since it appears to be caused by hardware
itself.
By the way, I use a raster having the following characteristics :
rows: 55109
cols: 54792
cells: 3019532328
but having lots of null values (see image below). Is there a way to speed up
the execution ignoring null values (I guess they are nulll values -
displaying "*" when querying) ?
<http://osgeo-org.1560.x6.nabble.com/file/n5047964/snap.png>
Many thanks for sharing all this, Hamish.
Bye,
simon
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-sun-use-automaticcaly-stopped-process-tp5047682p5047964.html
Sent from the Grass - Users mailing list archive at Nabble.com.
