[GRASS-user] Rendering labels in GRASS Cartographic Composer from vector layer
RichardC
richtcooper at hotmail.com
Fri Apr 19 23:12:12 PDT 2013
I'm attempting to add labels from a vector layer column to a map, but so far
haven't succeeded.
I've run v.labels to generate a file:
v.label labels=hydrobasins
map=hydobasins_asia_vc_chaophraya_vc_vcatadd_vc at hydrolayers column=SUB_NAME
type=centroid font=DejaVuSansMono
The file generated is attached: hydrobasins
<http://osgeo-org.1560.x6.nabble.com/file/n5048403/hydrobasins> .
I then edit the .psmap that I originally exported from the GRASS
Cartographic Composer, adding the following lines:
labels hydrobasins at hydrolayers
end
NOTE: hydrobasins is located in the hydrolayers MAPSET:
/grassdata/hydrology/hydrolayers/paint/labels
When I import the modified .psmap file and click on preview, I'm unable to
see the labels?
I'd be grateful for any suggestions as to where I might be going wrong, or
if a font issue?
Thanks,
Richard
GRASS 6.4.2
Ubuntu Precise
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-labels-in-GRASS-Cartographic-Composer-from-vector-layer-tp5048403.html
Sent from the Grass - Users mailing list archive at Nabble.com.
