[GRASS-user] Rendering labels in GRASS Cartographic Composer from vector layer
RichardC
richtcooper at hotmail.com
Sat Apr 20 22:33:37 PDT 2013
>From the above reference:
> (the default) is measured in map units. So in your case it would make the
> labels sized as 100 meters on the map. If you zoom way out that becomes
> very tiny and the label disappears. (see also the d.labels min and max
> options)
If I set a label size in v.label (pts), then this appears to take precedence
over the label size setting (in map units). However, if I don't set a label
size (in pts), no matter the label size setting (ie., map units), the labels
are not displayed. Or is this because my layer is in lat long degrees?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-labels-in-GRASS-Cartographic-Composer-from-vector-layer-tp5048403p5048537.html
Sent from the Grass - Users mailing list archive at Nabble.com.
