[GRASS-user] Rendering labels in GRASS Cartographic Composer from vector layer
RichardC
richtcooper at hotmail.com
Sat Apr 20 23:27:03 PDT 2013
It appears I can set the label size (map units) from the command line and the
label re-sizing works as expected (provided I omit the fontsize option).
However, I can't seem to omit the fontsize option if running from the module
window.
E.g. this works for a lat long layer, input in the command console, where
the labels change in size on zooming.
v.label labels=hydro_africa_lables.lbl map=hydrobasins_africa at hydrolayers
column=MAJ_NAME size=0.25 color=red
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-labels-in-GRASS-Cartographic-Composer-from-vector-layer-tp5048403p5048538.html
Sent from the Grass - Users mailing list archive at Nabble.com.
