[GRASS-user] GDAL libgdal1.6.0.so.1 error (REPOST)
stimon stimonmail at gmail.com
Sun Apr 21 03:42:38 PDT 2013
I am reposting my question because the first time I forgot to suscribe and
the message was not sent to the mailing list. Sorry for the inconvenience.
Hello everyone,
I am trying to use GRASS backend with 52norh WPS server, so I have followed
this instructions
(http://52north.org/communities/geoprocessing/wps/tutorials/WPSGRASSLinux.html)
to install GRASS 7 in ubuntu 12.10.
After fixing some python issues by setting PYTHON_HOME to /usr and then a
symlink to /usr/bin/python, it seemed I got it to work.
But now, when I try to launch r.los (via WPS) I get a GDAL related error.
>From the log:
<ERROR timestamp="11:50:28">
GDLA error while import. Unable to create input location from input
/home/administrador/grass/temp/ccb06c6f-74ba-4c6d-9d14-16b62b9b9067.tif GDAL
log:
/usr/local/grass7.0.svn-x86_64-unknown-linux-gnu-10_11_2012/bin/r.in.gdal:
error while loading shared libraries: libgdal1.6.0.so.1: cannot open shared
object file: No such file or directory
</ERROR>
I have installed GDAL 1.9.2 in ~/gdal192. the LD_LIBRARY_PATH is set:
administrador at torrevision:~/gdal192$ echo $LD_LIBRARY_PATH
/home/administrador/gdal192
Added the path to ldconf:
administrador at torrevision:~/gdal192$ sudo ldconfig -v | grep gdal
[sudo] password for administrador:
/home/administrador/gdal192:
        libgdalconstjni.so.1 -> libgdalconstjni.so
        libgdal.so.1 -> libgdal1.6.0.so.1
        libgdaljni.so.1 -> libgdaljni.so
        libgdal.so.1 -> libgdal.so.1.16.0
Maybe the problem is "libgdal.so.1 -> libgdal1.6.0.so.1" because the second
one it's not present while the first it is, So I also tried to set another
symlink from libgdal1.6.0.so.1:
dministrador at torrevision:~/gdal192$ ls -l
total 60300
drwx------ 2 administrador administrador     4096 abr 12 10:36 altitud
-rwxr-xr-x 1 administrador administrador    54931 dic 10 16:36 gdalinfo
drwxrwxrwx 2 administrador administrador     4096 abr  3 18:32 javainfo
lrwxrwxrwx 1 root          root                12 abr 19 11:50
libgdal1.6.0.so.1 -> libgdal.so.1
-rwxr-xr-x 1 administrador administrador   112705 nov 22 18:10
libgdalconstjni.so
lrwxrwxrwx 1 root          root                18 abr 19 11:30
-rwxr-xr-x 1 administrador administrador  1312184 nov 22 18:10 libgdaljni.so
lrwxrwxrwx 1 root          root                13 abr 19 11:30
lrwxrwxrwx 1 administrador administrador       17 abr  3 18:32 libgdal.so ->
libgdal.so.1.16.2
lrwxrwxrwx 1 administrador administrador       17 abr  3 18:32 libgdal.so.1
-> libgdal.so.1.16.2
-rwxr-xr-x 1 administrador administrador 44048076 nov 22 18:07
libgdal.so.1.16.2
-rwxr-xr-x 1 administrador administrador  5078163 nov 26 13:29 libltidsdk.so
lrwxrwxrwx 1 administrador administrador       19 abr  3 18:32 libNCSCnet.so
-> libNCSCnet.so.0.0.0
libNCSCnet.so.0 -> libNCSCnet.so.0.0.0
-rwxr-xr-x 1 administrador administrador   590457 nov 22 14:34
libNCSCnet.so.0.0.0
lrwxrwxrwx 1 administrador administrador       19 abr  3 18:32 libNCSEcwC.so
-> libNCSEcwC.so.0.0.0
libNCSEcwC.so.0 -> libNCSEcwC.so.0.0.0
-rwxr-xr-x 1 administrador administrador    81508 nov 22 14:34
libNCSEcwC.so.0.0.0
lrwxrwxrwx 1 administrador administrador       18 abr  3 18:32 libNCSEcw.so
-> libNCSEcw.so.0.0.0
libNCSEcw.so.0 -> libNCSEcw.so.0.0.0
-rwxr-xr-x 1 administrador administrador  8644546 nov 22 14:34
libNCSEcw.so.0.0.0
lrwxrwxrwx 1 administrador administrador       19 abr  3 18:32 libNCSUtil.so
-> libNCSUtil.so.0.0.0
libNCSUtil.so.0 -> libNCSUtil.so.0.0.0
-rwxr-xr-x 1 administrador administrador   713782 nov 22 14:34
libNCSUtil.so.0.0.0
-rwxr-xr-x 1 administrador administrador   608641 nov 22 18:10 libogrjni.so
lrwxrwxrwx 1 root          root                12 abr 19 11:30
libogrjni.so.1 -> libogrjni.so
-rwxr-xr-x 1 administrador administrador   472066 nov 22 18:10 libosrjni.so
libosrjni.so.1 -> libosrjni.so
I don't know if I am making a mess, but I don't know what else I can do. I
have been about 3 hours searching and reading about this lib problem without
sorting it out.
I have to say GDAL works fine, I installed it to work with AIG rasters in
Geoserver before trying GRASS. However with GRASS I get this error.
Thank very much for your help.
Santi
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-libgdal1-6-0-so-1-error-REPOST-tp5048562.html
Sent from the Grass - Users mailing list archive at Nabble.com.
