[GRASS-user] GDAL libgdal1.6.0.so.1 error (REPOST)
Markus Metz markus.metz.giswork at gmail.com
Mon Apr 22 01:05:22 PDT 2013
On Sun, Apr 21, 2013 at 12:42 PM, stimon <stimonmail at gmail.com> wrote:
> ... when I try to launch r.los (via WPS) I get a GDAL related error.
> From the log:
> <ERROR timestamp="11:50:28">
> GDLA error while import. Unable to create input location from input
> /home/administrador/grass/temp/ccb06c6f-74ba-4c6d-9d14-16b62b9b9067.tif GDAL
> log:
> /usr/local/grass7.0.svn-x86_64-unknown-linux-gnu-10_11_2012/bin/r.in.gdal:
> error while loading shared libraries: libgdal1.6.0.so.1: cannot open shared
> object file: No such file or directory
> </ERROR>
> I have installed GDAL 1.9.2 in ~/gdal192. the LD_LIBRARY_PATH is set:
> administrador at torrevision:~/gdal192$ echo $LD_LIBRARY_PATH
> /home/administrador/gdal192
>         libgdal.so.1 -> libgdal1.6.0.so.1
>         libgdal.so.1 -> libgdal.so.1.16.0
There are two links called libgdal.so.1, For gdal 1.9.2 you would need
libgdal.so.1 -> libgdal.so.1.16.2, but you have libgdal.so.1 ->
libgdal.so.1.16.0 which refers to gdal 1.9.0. The first link,
libgdal.so.1 -> libgdal1.6.0.so.1 comes most probably from an older
gdal version that was probably installed system-wide and then only
partially removed. Quite a mess it seems. You could either completely
remove all traces of the old gdal installation or hack Platform.make
to force link to the installation in /home/administrador/gdal192 by
adjusting the gdal link flags.
> Maybe the problem is "libgdal.so.1 -> libgdal1.6.0.so.1" because the second
> one it's not present while the first it is, So I also tried to set another
> symlink from libgdal1.6.0.so.1:
> libgdal1.6.0.so.1 -> libgdal.so.1
But now you have
and
a circularity.
> -rwxr-xr-x 1 administrador administrador   112705 nov 22 18:10
> libgdalconstjni.so
> lrwxrwxrwx 1 root          root                18 abr 19 11:30
> libgdalconstjni.so.1 -> libgdalconstjni.so
> -rwxr-xr-x 1 administrador administrador  1312184 nov 22 18:10 libgdaljni.so
> lrwxrwxrwx 1 root          root                13 abr 19 11:30
> libgdaljni.so.1 -> libgdaljni.so
> lrwxrwxrwx 1 administrador administrador       17 abr  3 18:32 libgdal.so ->
> libgdal.so.1.16.2
> lrwxrwxrwx 1 administrador administrador       17 abr  3 18:32 libgdal.so.1
> -rwxr-xr-x 1 administrador administrador 44048076 nov 22 18:07
> libgdal.so.1.16.2
> -rwxr-xr-x 1 administrador administrador  5078163 nov 26 13:29 libltidsdk.so
> lrwxrwxrwx 1 administrador administrador       19 abr  3 18:32 libNCSCnet.so
> -> libNCSCnet.so.0.0.0
> libNCSCnet.so.0 -> libNCSCnet.so.0.0.0
> -rwxr-xr-x 1 administrador administrador   590457 nov 22 14:34
> libNCSCnet.so.0.0.0
> lrwxrwxrwx 1 administrador administrador       19 abr  3 18:32 libNCSEcwC.so
> -> libNCSEcwC.so.0.0.0
> libNCSEcwC.so.0 -> libNCSEcwC.so.0.0.0
> -rwxr-xr-x 1 administrador administrador    81508 nov 22 14:34
> libNCSEcwC.so.0.0.0
> lrwxrwxrwx 1 administrador administrador       18 abr  3 18:32 libNCSEcw.so
> -> libNCSEcw.so.0.0.0
> libNCSEcw.so.0 -> libNCSEcw.so.0.0.0
> -rwxr-xr-x 1 administrador administrador  8644546 nov 22 14:34
> libNCSEcw.so.0.0.0
> lrwxrwxrwx 1 administrador administrador       19 abr  3 18:32 libNCSUtil.so
> -> libNCSUtil.so.0.0.0
> libNCSUtil.so.0 -> libNCSUtil.so.0.0.0
> -rwxr-xr-x 1 administrador administrador   713782 nov 22 14:34
> libNCSUtil.so.0.0.0
> -rwxr-xr-x 1 administrador administrador   608641 nov 22 18:10 libogrjni.so
> lrwxrwxrwx 1 root          root                12 abr 19 11:30
> libogrjni.so.1 -> libogrjni.so
> -rwxr-xr-x 1 administrador administrador   472066 nov 22 18:10 libosrjni.so
> libosrjni.so.1 -> libosrjni.so
> I don't know if I am making a mess, but I don't know what else I can do. I
> have been about 3 hours searching and reading about this lib problem without
> sorting it out.
> I have to say GDAL works fine, I installed it to work with AIG rasters in
> Geoserver before trying GRASS. However with GRASS I get this error.
> Thank very much for your help.
> Santi
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-libgdal1-6-0-so-1-error-REPOST-tp5048562.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
