[GRASS-user] GDAL libgdal1.6.0.so.1 error (REPOST)
Santiago Timón stimonmail at gmail.com
Mon Apr 22 01:59:08 PDT 2013
Hi Markus,
I have removed the default ubuntu gdal installation using synaptic.
administrador at torrevision:~$ sudo ldconfig -v | grep gdal
/home/administrador/gdal192:
libgdalconstjni.so.1 -> libgdalconstjni.so
libgdal.so.1 -> libgdal.so.1.16.2
libgdaljni.so.1 -> libgdaljni.so
The symlinks in gdal folder:
administrador at torrevision:~/gdal192$ ls -lah | grep ^l
lrwxrwxrwx  1 root          root            18 abr 19 11:30
lrwxrwxrwx  1 root          root            13 abr 19 11:30 libgdaljni.so.1
-> libgdaljni.so
lrwxrwxrwx  1 administrador administrador   17 abr  3 18:32 libgdal.so ->
libgdal.so.1.16.2
lrwxrwxrwx  1 administrador administrador   17 abr  3 18:32 libgdal.so.1 ->
libgdal.so.1.16.2
lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSCnet.so
-> libNCSCnet.so.0.0.0
lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSCnet.so.0
lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSEcwC.so
-> libNCSEcwC.so.0.0.0
lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSEcwC.so.0
lrwxrwxrwx  1 administrador administrador   18 abr  3 18:32 libNCSEcw.so ->
libNCSEcw.so.0.0.0
lrwxrwxrwx  1 administrador administrador   18 abr  3 18:32 libNCSEcw.so.0
-> libNCSEcw.so.0.0.0
lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSUtil.so
-> libNCSUtil.so.0.0.0
lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSUtil.so.0
lrwxrwxrwx  1 root          root            12 abr 19 11:30 libogrjni.so.1
-> libogrjni.so
lrwxrwxrwx  1 root          root            12 abr 19 11:30 libosrjni.so.1
-> libosrjni.so
But GRASS still looks for libgdal1.6.0.so.1
</INFO>
<ERROR timestamp="10:56:35">
GDLA error while import. Unable to create input location from input
/home/administrador/grass/temp/45ccd92d-daf2-4d80-abc3-a3e14bbc3f4f.tif
GDAL log: /usr/local/grass7.0.svn-x86_64-unknown-linux-gnu-10_11_2012/bin/r.in.gdal:
error while loading shared libraries: libgdal1.6.0.so.1: cannot open
shared object file: No such file or directory
</ERROR>
Thank you so much for your help,
Santi
2013/4/22 Markus Metz <markus.metz.giswork at gmail.com>
> On Sun, Apr 21, 2013 at 12:42 PM, stimon <stimonmail at gmail.com> wrote:
> > ... when I try to launch r.los (via WPS) I get a GDAL related error.
> > From the log:
> > <ERROR timestamp="11:50:28">
> > /home/administrador/grass/temp/ccb06c6f-74ba-4c6d-9d14-16b62b9b9067.tif
> GDAL
> > log:
> shared
> > </ERROR>
> > I have installed GDAL 1.9.2 in ~/gdal192. the LD_LIBRARY_PATH is set:
> > administrador at torrevision:~/gdal192$ echo $LD_LIBRARY_PATH
> >         libgdal.so.1 -> libgdal1.6.0.so.1
> >         libgdal.so.1 -> libgdal.so.1.16.0
> There are two links called libgdal.so.1, For gdal 1.9.2 you would need
> libgdal.so.1 -> libgdal.so.1.16.2, but you have libgdal.so.1 ->
> libgdal.so.1.16.0 which refers to gdal 1.9.0. The first link,
> libgdal.so.1 -> libgdal1.6.0.so.1 comes most probably from an older
> gdal version that was probably installed system-wide and then only
> partially removed. Quite a mess it seems. You could either completely
> remove all traces of the old gdal installation or hack Platform.make
> to force link to the installation in /home/administrador/gdal192 by
> adjusting the gdal link flags.
> > Maybe the problem is "libgdal.so.1 -> libgdal1.6.0.so.1" because the
> second
> > one it's not present while the first it is, So I also tried to set
> another
> > symlink from libgdal1.6.0.so.1:
> > libgdal1.6.0.so.1 -> libgdal.so.1
> But now you have
> and
> a circularity.
> > -rwxr-xr-x 1 administrador administrador   112705 nov 22 18:10
> > libgdalconstjni.so
> > -rwxr-xr-x 1 administrador administrador  1312184 nov 22 18:10
> libgdaljni.so
> libgdal.so ->
> > libgdal.so.1.16.2
> libgdal.so.1
> > -rwxr-xr-x 1 administrador administrador 44048076 nov 22 18:07
> > libgdal.so.1.16.2
> > -rwxr-xr-x 1 administrador administrador  5078163 nov 26 13:29
> libltidsdk.so
> libNCSCnet.so
> > libNCSCnet.so.0 -> libNCSCnet.so.0.0.0
> > -rwxr-xr-x 1 administrador administrador   590457 nov 22 14:34
> > libNCSCnet.so.0.0.0
> libNCSEcwC.so
> > libNCSEcwC.so.0 -> libNCSEcwC.so.0.0.0
> > -rwxr-xr-x 1 administrador administrador    81508 nov 22 14:34
> > libNCSEcwC.so.0.0.0
> libNCSEcw.so
> > libNCSEcw.so.0 -> libNCSEcw.so.0.0.0
> > -rwxr-xr-x 1 administrador administrador  8644546 nov 22 14:34
> > libNCSEcw.so.0.0.0
> libNCSUtil.so
> > libNCSUtil.so.0 -> libNCSUtil.so.0.0.0
> > -rwxr-xr-x 1 administrador administrador   713782 nov 22 14:34
> > libNCSUtil.so.0.0.0
> > -rwxr-xr-x 1 administrador administrador   608641 nov 22 18:10
> libogrjni.so
> > libogrjni.so.1 -> libogrjni.so
> > -rwxr-xr-x 1 administrador administrador   472066 nov 22 18:10
> libosrjni.so
> > libosrjni.so.1 -> libosrjni.so
> > I don't know if I am making a mess, but I don't know what else I can do.
> I
> > have been about 3 hours searching and reading about this lib problem
> without
> > sorting it out.
> > I have to say GDAL works fine, I installed it to work with AIG rasters in
> > Geoserver before trying GRASS. However with GRASS I get this error.
> > Thank very much for your help.
> > Santi
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/GDAL-libgdal1-6-0-so-1-error-REPOST-tp5048562.html
> > Sent from the Grass - Users mailing list archive at Nabble.com.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130422/882b97dc/attachment-0001.html>
