[GRASS-user] limitations of r.stream.order
    Rich Shepard
    rshepard at appl-ecosys.com
    Sun Apr 21 12:20:45 PDT 2013
On Sun, 21 Apr 2013, Carlos Grohmann wrote:
> Is there any limitation on the size of rasters that r.stream.order can
> handle? I'm trying to run it for a large area (rows: 8640, cols: 6480) and
> it gives me several of these warnings: WARNING: Stream network may be too dense...
Carlos,
   Try adjusting the threshold in r.watershed that you use to create the
accumunlation map. All the r.basin.* series are sensitive to threshold size,
so everywhere you specify a threshold value try increasing it -- greatly --
until you get a number that works for your needs.
Rich
Richard B. Shepard, Ph.D.          |   Integrity - Credibility - Innovation
Applied Ecosystem Services, Inc.   |
<http://www.appl-ecosys.com>     Voice: 503-667-4517      Fax: 503-667-8863
